So I had my snow blower in for a carb rebuild. When I got it back, I noticed it dripping whenever I over primed it or tipped it back. Today, I took the float and needle apart and cleaned it. It worked, but a few hours later when I tried it, it leaked about two drops. Is there anything that I should try or should I not worry about it?
If you prime too much, it can leak. Also check the bowl to make sure they tightened it up properly. If its tight, might be the gasket on the bowl was damaged when they reassembled it. If you paid to have the work done, you should take it up with the shop who should make good on their work.
Another thing, when the carb was rebuilt was the inside of the gas tank also cleaned? If there's any residual gunk in there it could be getting into the carb and messing with the seal on the float needle.
CL
If you're "tipping" your snow blower, a few drips is normal. Also, as mentioned, the primer bulb will cause excess fuel to leak out...normal. If your machine is running correctly now, I would wait to see if the drips disappear. If the tank has a shutoff valve, always use it. If not, install one and use it. MH
Good. Just keep an eye on it and store it wisely. MH
