1 - 12 of 12 Posts
If'it was not interfering before something changed... What changed? You may have to repeat the process to make that determination. I've had a couple of them apart but never had this problem.
Only thing that I did was replace the emulsion tube, and the jet needle
Did you compare the old one to the new one ??
Did you remove the plate from the shaft, any chance you put the plate back on the wrong side of the shaft ??
They looked close enough, so I didn't bother measuring, or anything. Didn't do anything with the plate.
I'll try taking some pics tonight.
I have heard that style needs the emulsion tube removed before the bowl is removed. If you don't do it in the right order you can bend the emulsion tube.
Eh, we've all been there. I might suggest an inexpensive jewelry cleaner. Please look up on you tube using them for carb cleaning. You will be amazed.
Hopefully now that I got it running we don't have use a snow removal service as per my mother-in-law/ land lady's threats.
1 - 12 of 12 Posts
