I was givin a nice used "95" Toro 1132 Powershift from my boss and although everything works now after a little work I realized after going through the service records that the auger gearbox/diff oil was never changed. Should I change it or does it even matter?
If there is not lube in the housing you will smoke those gears fast. I would put new gear seals in it too. Use non-syntheic 80-90 gear oil
