1 - 14 of 14 Posts
you are right, something doesn't look right
after looking at that one maybe my craftsman wasn't assembled so bad after all :D
It is just the position of the auger and the angle of the picture.
The augers should look like this when installed correctly. /// o \\\
When swapped side to side they look like this. \\\ o ///
Yep. But for some reason ( photo angle) they look like this \\\o\\\.
Could be a point of negotiating, it only clears 15".....half price.
I slept on this and took another look. I'm still not sure if they're installed the correct way. It makes my head hurt to try to figure this out.:confused:
To me they look fine. The picture is just at an off angle.
They're fine. Since they are the stamped modules you don't have the continuity of the helical bands. The broken segments break the flow and the camera angle lets odd things into the image.
If they were backwards you'd know it, trust me. :eek:
Pete
Pete
Camera angle just makes them look strange. I looked at it for a minute, got it figured out.
I thought that they should both scoop the snow into the impeller at the same time, but I was wrong. I took a look at my simplicity and they are 90 degrees apart. So they alternate, left then right.
1 - 14 of 14 Posts
