1 - 10 of 10 Posts
I took some advice from another Forum user ( sorry...cannot remember who) , and this person advised against pushing, or even allowing the unit to move on it's own. "Guide it" he said....and he is exactly right. I have been a bit disturbed of late with all the talk of the wandering Autoturn. I have also experienced it myself, and replaced the steel shoes with Poly ones. I have not gone through a winter yet with the Poly ones, although they do seem to make it better. So today Sept 25th/18 ( My neighbors must think I have lost my senses) , I took my 2014 Ariens, which I have always held the brand name in high regard, onto the driveway, and figuratively blew out the driveway. No snow.Leaves. Just me playing. Up and Down...again and again.
The secret is to pullback on the handlebars with a low to moderate amount of pressure. Don't push it, and don't let it maneuver itself....just pull back slightly, and the unit goes as straight as an arrow.The fact is in going uphill.....it doesn't move side to side at all....and it does going downhill. I find that I have to pull back more on the left handle than the right:kiss::wink2::grin:, but it's easy to do. I used it for 30 minutes, and it felt really good.
If this helps anyone worrying about this issue, then it was well worth it.
I told you it was butter
with snow you wont even have to pull back
the 2014 2016 have more down force on the bucket then the relocated axle models
iam glad to have the higher downforce axle location
My driveway is junk lots of dips very uneven its still laser straight
can also go right down the side of the car or the house laser straight
adjust bucket and scraper properly with the poly shoes butter
:smile_big:Thanks 1132LE....I appreciate your reply.
So, are the new 2018 models better or worse than the 2014-2016 models???
From what I understand about these blowers, they re positioned the rear axle in 2017, which made this whole situation much better. So I guess the answer to your question is yes, they probably are better. But, I have talked to a few people who own the older ones, and they prefer the ones without the adjustment, as they are front heavy, and really dig into the snow. I ,myself have a 2014, and have now put on Poly shoes, and it seems to be Ok.
Have to wait until a heavy snowfall here is Sask to really see.:grin:
I am a new Ariens owner This will be my First winter with it. I think you are 100% rite about guiding it .But I have been looking at a lot of Youtube Videos where people are fighting there snowblower by going to fast. When I got my Ariens and adjusted everything by the manual. 1st gear was way too fast for me I adjusted the speed at my walking pace.It seems that the Auto turn Problem disappeared.and controlling it with a little backward grip was a lot easier once I slowed the travel speed down. But that made the reverse faster. Witch I don't use that much. So I cut another notch on the speed controller Now I have 3 Reverses
Those wheels seem impressive....if my Poly Shoes don't correct the pulling, then the Custom Shoes may be the next step.We'll see what happens. Here in Sask, we've already had 2 days of snow, melting as it hits the ground, but more threatening to come.
I bet your neighbors got a good laugh watching that scene. :thumbsup:
1 - 10 of 10 Posts
