Craftsman 10-32 driftbreaker
1.1K views 11 replies 5 participants last post by  Oneacer
I just picked up a Craftsman driftbreaker, model 536.882700. Overall it is pretty clean, starts on the second or third pull, and seems to run strong.
However, I am having a few issues with the drive system.
First is when in gear, even with the clutch disengaged, it wants to drive. I have to put it in neutral to get it to stand still. I checked the belt, and it is the same number as the impeller drive, and that one idles just fine.
Second, and the bigger issue, when driving it skips and start stops. I have spent all day messing with it. The chain from the secondary shaft to the axle seems to be super loose, and I think it is running up on top of the sprockets and then slipping. It doesn't push itself through the snow will at all, and I am worried that it i keep using it this way it will trash the transmission.
I tried putting a washer in between the secondary shaft and transmission mount, like HCBPH mentioned in his rebuild thread, but the photos aren't available so I couldn't tell exactly what was done. This did seem to tighten the chain from the trans to the shaft, but not the other. I also removed the chain and cleaned and relubricated it, going that it would wrap over the sprocket easier, but that didn't help either. I thought about removing a link (yes, it is that loose) but it doesn't seem to have quite enough slack for that. I can't see any way to adjust the slack. Any help or suggestions are appreciated.
Also, if someone knows a part number for bearings to replace the bushings on the axle and auger that would be great.
I will try to get some photos later today after the thing is thawed out from the trial in the current 12" of wet snow I have.
#2 ·
Here is a photo of the slack in the chain. Also some photos of the machine.
I took video of the chain skipping when I back drive the wheel, but I can't get it to load. The system says the file extension (MP4) is not allowed. I will try to figure that out and post the video, and maybe a video of it running.
#10 · (Edited)
I'm no chain expert but I have replaced quite a few over the years. To me the chain looks OK but the sprocket is worn, which would increase the pitch and explain the looseness.
However to be fair, it is difficult to know just by looking at the chain.
A chain gage would give you a definite answer.
#3 ·
That would mean the friction disc is still engaging the drive plate ... possible a return spring missing? etc,..
I would surmise a damaged friction disc rubber ....
#5 · (Edited)
To me it looks like the chain is too loose
It's not loose; it's either worn out (see "stretch" below), or simply the wrong pitch for the gears (it looks like the pitch is too short?).
Chain "stretch" is caused by lack of lubrication and then the chain’s pitch grows in length as it wears. The growth comes from the bushings wearing with the chain pins. Over time, the inner diameter of these bushings increases and the pins groove out. Measure the length of 10 links and then divide by 10 to get the average pitch. If it's 0.5% greater than the original pitch (or more), it's time for a new chain, and perhaps new sprockets.
Silver Body jewelry Nickel Jewellery Circle
These are the specs for your 50640 chain:
  • Chain Pitch: 0.500"
  • Roller Diameter: 0.306"
  • Roller Width: 0.250"
  • Pin Diameter: 0.141"
  • Plate Thickness: 0.050"
Here is a replacement for your 50640 chain:
They can probably make a 50641 if you need that one.
#8 ·
Sorry, been gone for a while. Here's the most common reason for chains slipping. Unless you machine it and replace the sprocket, it's easier to replace it if you can find a parts machine. You may have to shim the sprocket if it's got slop in it, but that's not too difficult. If anyone wants the doc on the rebuild I did, send me an email to pch-hcbph@msn.com and I'll forward it to you.
#9 ·
Thanks for the responses. I have been out of town and buried in other projects also. I measured the chain, and it didn't seem to be overly stretched. However 10 feet of chain was only $30 from Grainger, so I went ahead and bought that. It just arrived yesterday, so hopefully will install that soon and give it a try.
HCBPH
I tried emailing you and it bounced as message blocked, mailbox unavailable.
If you don't mind emailing your rebuild writeup to me, it is my username on the forum @gmail.com.
#11 ·
Thanks again for all of the help.
I found the idler sprocket at Adam's small engines, so I went ahead and ordered that. I finally got a chance to install the new chains on the drive system and the new sprockets on Friday. The slack does not seem to be any different, and the chain still slips. It appears that it is slipping on the small idler sprocket and not on the larger axle sprocket like I thought it would. So I am looking for options.
I can see if I can get a new axle sprocket and weld it on the shaft. I am not an experienced or skilled welder, but I can probably get it to hold. My biggest concern is if I cause any warpage of either shaft or sprocket.
Another thought is to replace the bushings with bearings, and redrill the mounting holes to move the axle down a little to remove slack from the chain. I was looking at these bearings:
Again thanks for all of the help. Sorry I have been slow to respond but am in the middle of a construction project right now that is taking all of my spare time. I am hoping to get this going before we get into the full snow season here in Colorado.
