original problem: Auger does not turn, but impeller does. (Ran over an object, shear bolts did not do their job) Okay, I finally started to work on this machine today. Havent removed the auger and gear yet, as I am still not sure the correct or best way to do so. Any help would be appreciated. One thing I did do, was crack open the auger gear housing to see if I could see any broken teeth in there, and everything looks good on both gears. Could it be just the key that broke or came loose? It appears the axle is turning through the worm gear, so it makes me think the key is the issue?
If so, whats my next plan of attack. I would still like to get the augers loose from axle so the sheer bolts will work properly next time. Can I just remove the axle without removing the housing and impeller shaft?
Thanks Art
See original post for questions
http://www.snowblowerforum.com/foru...rum.com/forum/craftsman-snowblowers/36033-521-auger-wont-turn-when-engaged.html
Thanks Art
