1 - 11 of 11 Posts
have to replace drive disc on a 26". need help in removing and the new disc I recieved does not have a screwdriver slot for jam nut. there is slot down side of shaft. is there special tool? any help would be appreciated
Craftsman has a lot of older and newer machines, they have been making them for many years.
It would help greatly if we knew what the model number is … also, are you referring to the main drive plate that the friction disc rides against, or the actual friction disc. It is unusual that the drive plate would need replacing, as it is the friction disc that is the wear item, even then, they last a long time if properly adjusted.
model 247.88691...rubber ring came off of disc and metal part of ring put grooves in plate.
my problem is how to get plate off and ive seen a picture of a screw driver slot on bearing shaft to hold to tighten jam nut but the replace ment...656.04055 has like a keyway cutout on jam nut shaft..... special tool? or just screw driver?
Your missing one number in the model number.247.886911?. If so the stud may have a slot. Blip you may be able to blip off the nut with an impact.
number 247.886910.
haven't figured out how to get to underside of bracket yet. It might have screw driver slot.
Looks like the drive plate itself is attached with a flanged nut to the swing bracket … an impact gun should take that off with ease.
look up part no 656.04055.........what do I use to hold bearing bolt while tightening jam nut
i was thinking i was missing washer with cutout but if it is built into plate is even better
thank you much
1 - 11 of 11 Posts
