I have a Creary Bear Cat 5hp Tecumseh, runs at idle, stalls under light load, thinkin carb needs adjusting, any ideas would help. No model No#. Any idea on plug type, and gap.
I gap plugs at .032. (As a courtesy to classiccat, I had .035 as the gap by error, I added this later, I gap everything at .32 only because it's close enough to most specs, however if the gap is off by a lot it throws the ignition timing off and could cause not starting, backfiring. I've seen new mower plugs gapped at .050!!!
Could be a carb adjustment but also a dirty carb. Usually, not always, an indication of a dirty carb, you will need to keep some of the choke on when warmed.
Welcome to the forum!
I'd bet that it's due to compression loss...it may be due for a new head gasket &/or valve job.
All L-head tecumseh engines have a spark gap of 0.030" regardless of ignition type (standard point or solid state) (I believe JLawrence had a typo up there).
