1 - 15 of 15 Posts
Late 80's machine getting some TLC for the upcoming season
As picked up:
Ordered new tires, main shaft outer bushings, and an impeller kit
One of the blades on the impeller needs to be bent back
Waiting for the parts
Looks to be in good shape, how old is it? I don't know anything about the build quality of the JD units.
I have the same model but my impeller blades are different. They are thicker and a different shape.
Based on the serial its a 1989
Needed to take the axles and diff out to get to the bushings
Long overdue!
Even more overdue...
this diff has never been apart, no doubt about it
Cleaned up easy though
This machine will definitely benefit from an impeller kit
Tire beads are quite stubborn
Just waiting for parts now
Impellar kit?
Hello! Last weekend I nearly completed resurrecting a 1973 832. I'm excited to use it. You mentioned "could use an impellar kit" regarding your wonderful 1032. Am I overlooking something painfully obvious? I thought the rubber flaps attached to the outer edges of the impellars are taylor made, custom fit on site. No?
new skins are a little taller than expected, uh oh
had to tube them to seat on the rim
new valve and filter. Shoulda used a 90 valve and a straight filter but it should be fine
With the original tires it had a sloped back stance but now its just about level and should dig in better
With the back half done its now onto the impeller kit. Wont be very easy cause the reinforcing webs are right about where the bolts need to go.
Cleaned and adjusted the carb, changed the oil, fixed 2 bent blades and installed the impeller kit
The Fleet is ready for snow
looks good. definitely pretty cool that it has a real differential in it. i kept the axle out of a machine once because of that. i haven't found a use for the axle yet but was thinking it would work awesome for a gas powered wheel barrow or something.
you could put the filter first and then the fuel shutoff. not the most ideal way but makes things work with what you got.
No snow yet or any in sight so took the 1032 out for a spin today.
The impeller kit still needs some bedding-in anyways
How did you clean the gears and housing to get them to look so great?
What did you put on the machine for tires?? What size?? They almost look like Rototiller tires I put on my T/B Horse...
GLuck, Jay
1 - 15 of 15 Posts
