Hi all,
I cannot find a part number for the carburetor float bowl gasket. The carb repair kit (Ariens part # 20001184) comes with the gasket, but I do not need the entire kit. I have an AX 254 engine. Do you know if it's possible to get just the gasket? Thanks!
Go to ereplacementparts.com and search by engine model number or whatever and see if you can find the gasket itself. Then take that part number and do some more searching on amazon or ebay or whatever parts site and see if you have any luck.
I don't know where you live, but just take the old gasket to any small engine repair shop …. they'll probably give it to you, are just charge a minor amount.
As you can see, there are a million on line as well at Amazon, or anywhere.
As mentioned, do a little detective work on the engine, and match it up online, or as I mentioned, just see your local repair shop for a match.
https://www.amazon.com/FLYPIG-Carburetor-Float-Gasket-16010-ZE1-812/dp/B01NA09O99/ref=asc_df_B01NA09O99/?tag=hyprod-20&linkCode=df0&hvadid=241967373029&hvpos=1o3&hvnetw=g&hvrand=3564430245656058277&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003238&hvtargid=aud-801381245258:pla-486104111469&psc=1
