I just received a tickler from Amazon on this model. I have a regular mechanical Hobbs-style hour meter installed, but it lacks the other interesting features like the tach and the maintenance tickler. Let us know how it works out for you.
It was on the blower yesterday for the first time while making some carb adjustments. I didn't set up all the features such as service times, alarms, etc.; just looking at how the tach worked. It was initially set to "1P2R" (4 stroke 1 cylinder), but it was reading double the speed. Changed it to 1P1R (4 strokes 2 cylinders) and it was where I thought it should be compared to two other "meters"; a low-cost digital tach/hour meter, and my Treysit Sirometer. (Interestingly, the older digital gauge also had to be set to 1P1R when I first got it.) Seems to be a common issue. The instructions do say to try different settings if the reading is wrong.
The display is fairly large and clear, and having the backlight is a valued difference to the older one. This Runleader is also significantly heavier than my other meter, and sits firmly on the blower dash (using the "Velcro" tape).
Instead of winding the attached cable around the spark plug wire, I wound a short length of insulated #14 solid wire as described
in this post. The cable on this Runleader is shielded (coaxial); I connected a small alligator clip to the inner wire after folding the shield back and covering with shrink tubing. (Did the same with the other meter, so I was able to compare the readings at the same time, and disconnect one or the other at will.) This technique will enable using the meter on other gas engines without having to wind and unwind the cable from the spark wire.
The case appears to be sealed except underneath at the battery case and on top at the two buttons. The battery cover is surrounded by the "Velcro" mounting tape, and it's unlikely to be exposed to snow or water. However, the two control buttons on top could be. I might tape a piece of clear plastic over the top to protect the button area.
Have read a lot of posts referring to engines "bogging down" under different loads, and I do know that my blower engine does slow down at times as well, but the meter will provide objective data for assessing whether or not the changes are significant.
