I just got a Hechinger 523 on the cheap (I think). Google searches do not tell me much. It seems to start easy (once we realized it needs a key).
Ill probably sell my ancient Gilson now. id like to find some info about what I bought.
From some quick google searches it appears their lawn tractors are made by MTD so I would assume so are their snow blowers. Find some pictures of MTD 5/23s and see if they compare. Looks like that is a store brand local to PA. I have never heard of them before.
Thanks . I was just playing with it and determined a few things that I will need to work on.
Only wants to run on choke or half choke.
Seems to have a slight fuel drip from the carb (perhaps related?)
Techumseh engine (not something I need to work on)
I also discovered that the augers are attached with a bolt thru the axle. I assume that is not a sheer pin. So ill have to get into that as well.
Some sheer pins are actually bolts. If the bolt head has nothing on it they are probably fine. If you see 3 or 5 dashes from center to outer edge they are wrong. Also the bolts usually have 2 grooves cut in them that you can see if you take them out.
Someone else told me its a Murray not an MTD.
I do know that its got an HS50 Tech. Motor, and its made in Canada.
