Downsides to setting skids to the max height?
1 reading
3.8K views 5 replies 6 participants last post by  uberT
This might sound bonkers to some, but both the driveway and sidewalks (which we're responsible for clearing) are incredibly uneven.
I am wondering, if I just set the snow blower to the maximum height the skids allow, is there any downside beyond obviously leaving behind a few millimetres of snow behind? For example are there any safety concerns or could it cause more wear and tear?
Also are skids meant to be level? I mean there is a front and rear bolt, what happens if you have it pointed at an upward angle to jump over these kind of uneven surfaces?
:blowerhug:
#2 ·
set the skids evenly on a level surface. the down side to setting them high ( which i do at the start of winter) is the layer of snow left behind, which can turn to ice. in my situation, i prefer to build a layer of ice as it levels the driveway and i can then lower the skids on a flat driveway surface.
Reactions: uberT
#5 · (Edited)
:blowerhug:
With the bolt spacing on the shoes I don't think you could get them angled enough to make a difference, plus they would wear out to fast, they are designed to be installed level. I would invest in some armorskids and be done with it. Use JD in NJ's link he provided.
#6 ·
Yeah, it comes down to the melt/re-freeze scenario. Are you creating any safety issues for your family or those folks using the sidewalk? In my situation, with a steep drive, I pretty much have to get down to bare pavement before I wrap up. I can't leave a coating of snow behind:
