Hey there. Just bought this starter second hand off a farmer seller/salvage yard guy, really inexpensive because of one issue. Works perfect...however the prior owner sawed off the ground plug off...my electrician father did this often back in the day.
Anyway, I linked two images. The first is the switch opened up showing the ground plug (green wire)...soldered on, round base. The second image is of a replacement plug I have.
First off, do I really need to replace this? My thinking is I probably should. The problem is I don't believe one can simply buy this style of prong (let alone a standalone prong by itself) any more. Or can I? Maybe all round ground prongs are this type of base? I do have a couple old extension cords that have this style prong.
So...let's say I cannot simply buy/find the correct style base prong - so I then try this. Using a Dremel, cut off the replacement to length. Use the same Dremel cutting disc to then hog out two notches on the starter housing so the replacement u-shaped design fits snugly in the plug housing.
Then solder the replacement to the stub. Looks like the replacement is brass, the stub steel...any issues with two different metals? Also, would this be strong enough? My thinking is I need that base style of the original to fit inside there snugly in the mold top and bottom of the housing, maybe grind off a tad off the top outside edge of the stub per the thickness of the replacement, then solder it up.
Would this all work? Or is it truly necessary?
Thanks for any help/suggestions. I'm fine leaving it be...right up to the point where I get shocked if you know what I mean
