1 - 11 of 11 Posts
Hello, I'm looking for the original flat ribbed auger belt for my Ariens model #932026 snow blower, every where I look they show the V belt, but mine the 39" in circumference, flat and ribbed not V, here is one similar to what I need http://bit.ly/2fqB5r6 , I think this is the right belt but I need to make sure, 07225300, if I was to use the V belt the brake would destroy it because it would ride to high.
Thank you
see that's what worries me, it lists a V belt
"17 - 07219100 - V-Belt 4L-RMA .38 x .56 - (Used Only On Model(s): 026)."
is a V belt the same is this type of rib belt like I have? http://bit.ly/2fqB5r6
Thank you
this is the pulleys and the belt I took off this machine, im starting to wonder if someone put alternate parts on it.
I would guess that someone did, I have only seen that type of belt on a single stage snow blower
interesting, I wonder why someone would do this, anyway, anybody know a good source for these type of belts that hopefully I can get by size, I don't really want to buy new pulleys to get the correct belt.
Thank you
Take the Old Belt to a NAPA Auto Parts Store. This Company usually has "Knowledgeable" People that can Match Things up.
Agreed on auto parts stores, those are commonly used on cars and they should have a good selection.
I stopped by our napa and they found one that should work, I'm waiting on the new brake to arrive then I can put it all back together for this winter.
Thank you all for your input!
Let us Know How things work out. My Local Napa Guys are Extremely Knowledgeable, and have even Matched Bearings For Me by Size.
1 - 11 of 11 Posts
