Hi all,
Well, first real 2-stage snowblower that is. I have used a small 2 cycle MTD to clear off my deck for years. Did most of my snow removal with a JD tractor and plow.
Last winter I did have some problems getting into the back area to my back garage with my plow due to drifting. Had to cut a couple of passes with the little MTD and swore I didn’t want to do that again cause I am getting too old, so this year I made some changes.
Over the summer I picked up a bigger tractor and plow and also came across a good size snowblower for a nice deal. It is an Aries ST1336 LE and has a 13 HP Tecumseh engine with a 36-inch auger. The machine ran real good but would leak fuel from under the shroud when the thing was tilted back so I got a real good deal cause it was June and the guy didn’t want to mess with it, and I figured it couldn’t be that hard to fix.
One new carb bowl gasket later and no more fuel leak, and it still runs good.
Today I decided to check the belts and it is good I did. Both belts needed attention to say the least, and the finger guides were mis-adjusted to the point of damaging the belts. In fact there was a bunch of fuzz on the inside of the bottom cover when I took it off. I thought at first it might be from mice, but then I noticed the belts were wearing against the mis-adjusted finger guides.
Two new belts and a readjustment of the finger guides and she seems to work great. Was a bit of a challenge changing the belts cause you have to split the machine in half to do it but I took my time and everything worked out well. This is my first time working on a snowblower and I am enjoying the learning experience.
Also had to adjust the drive actuation lever. Machine would go great in all forward speeds. Heck, this thing would drag you down the drive in forward. You can’t stop it. However, in reverse, it was a bit halting and you could stop it if you tried. Took some slop out of the lever and now it will run you over in reverse just fine.
Nice forum here and I look forward to learning about snowblowers.
Here is a photo of my beast….
