That axle slop is either missing washer spacers, worn bushings, or the rim pin is not in the proper hole for the drive position.
If you don't have a welder, a piece of sheet metal can easily be repaired with some rivets and some scrap sheet metal ......
That unit is going to require a lot of TLC .... Clean, paint, grease, etc.....
Probably a decent machine for you to use for personal use, but bringing it to resale standards might not recoup your money and time.
