So I have a question. My old ford has the tecumseh 7hp motor on it and when snowblowing in low gear it will bog down in heavy snow. The snow was crusted over and probably a foot high or less. I am not sure if its just the nature of the beast, or if something is off. I have had the carb apart and it's clean. It runs like a raped ape when not under heavy load.
Thoughts?
May be the carb is not adjusted right , the rod from the governor is in wrong hole or the engine is plain tired from age
Nothing has been touched gov wise. The main jet in the carb is adjusted correctly as it runs great and does not pop.
I have never done a compression test.
Another thing. After running this blower you smell like exhaust. Like really bad. Fuel is fresh 91 octane non ethanol.
I plan on taking the carb apart again as it's been a year or so since I cleaned it. When I bought it I tore it down and cleaned it up. I replaced a few gaskets if I recall but overall it was in good shape.
great to see another Ford out there!!
It does sound like something isn't quite right with yours. I don't think it should bog that much on less than 12" of snow, crusty or not. I can't say on the exhaust smell, I guess I've never really paid it much attention, usually just happy to be able to get the machine out and throw some snow.
I replaced my impeller belt a couple years ago, and added a DIY impeller kit, and have noticed improved throw. I probably have some sort of carb issue developing, as I have to let it run with part choke for quite a while before I can throw at no-choke setting. But with the infrequency that I've had opportunity to run the Ford these past couple seasons, I just deal with it for now.
Good luck!
