Well. it's a Honda. we'll see.
After draining old gas and checking oil it started on 3rd pull and runs great. no smoke.That looks like a great machine.
Looks to be much better built than the Hondas made today.
Even the wheels look beefier.
It will be interesting what/if any issues you find.
I've had an HR215 bought new, and if you slam the blade clutch in, they will always try to stall. Treat it like a manual transmission . . . in until it starts to grab, a brief pause, and take it home. Well oved 2000 hours on mine, and lining is still close to new, so no, this is not bad for the clutch (well, unless you ride it forever . . .) and it what I was taught by the dealer at purchase. The clutch really only needs work if it slips or the blade freewheels when disengaged . . .After draining old gas and checking oil it started on 3rd pull and runs great. no smoke.
all 3 speeds works.
issue found. when trying to engage blade it starts to stall
Maybe the manual that @tabora provided I will figure it out.
thanks.
I'll let you know. Even trying to engage blades easily the engine bogs and stalls so perhaps the bearing is seized.I picked up a curbside HRR216 couple of years ago that had a bad blade clutch. I was able to buy just the bearing for $12 and salvage the clutch assembly by pounding out the old bearing and tapping the new bearing into place. Use the suggestion above to gently engage the clutch, and see if the bearing's any good. If it's bad, it will howl like crazy until you disengage the clutch.
Make sure the governor is working correctly. Easing the blade engagement helps the governor to catch up to the load applied to the engine.I'll let you know. Even trying to engage blades easily the engine bogs and stalls so perhaps the bearing is seized.
Well. it's a Honda. we'll see. View attachment 194775
