i'm looking for a fuel tank bracket for a tecumseh 8hp motor
I think there were a couple different ones. Do you have a pic of the tank or where it goes?
Plastic or metal tank?
i'll get a pic posted
Tank brackets
I doubt that 8's ever had the small tank though it should fit with the corresponding brackets, but there are at least a couple of brackets for the larger tank. Be sure to get both the upper and lower bracket or plan to redrill the lower one. Pretty sure the hole height is different between the 2 setups.
Paul
now i'm going to have to go over and look at the blower to see whats there and whats missing. maybe i'll keep his tank and put it on my 521 :)
Tanks
Here's a couple of the different tanks and mounts. A couple of these will only work with the corresponding tank also, just be aware of that. Along with that is where the outlet from the tank is located. Most have a plastic nipple but some have a rubber plug with an adapter to hook the gasline up to.
I've done a number of swaps between various motors, typically both the tank along with the mounts.
