Do others have this problem? You need to add gas to your snowblower. It's cold and you are tired and maybe your younger sons should be doing the snowblowing. You've turned off the machine and bring the plastic gas tank to the machine. Your gloves are stiff in the cold. You attempt and finally succeed in unscrewing the gas cap, reversing the spout/gasket and opening up the air vent. You proceed to try to pour gas from the can into the machine. You spill gas over the top outside of the snowblower's tank. Sometimes it's a lot, sometimes a little. Each time I'm afraid to restart the machine with the distinct smell of gas fumes.
I've tried using a funnel but the spout is ill fitting and can make things worse aiming at a tilting funnel. Holding the funnel in one hand while tilting the gas can with the other is difficult at best because of the weight of the can Is there a funnel made for the opening of such gas equipment?
