Anyone use this coating on a snowblower. Does it work or is it just magic in a bottle. Gemplers Silicone snowplow coating. Seems like cost per oz is much better thatn the ariens snow spray.
Says
ideal for snow plow blades, truck beds, snow throwers, shovels and other exposed metal and painted surfaces
  • Reduces friction for more efficient snow removal
  • Protects against rust and corrosion
  • Will not wash off
  • Covers approximately 500-1,000 sq. ft./gal.
Save time and money while removing snow this winter. This Silicone Snow Plow Coating is a colorless coating that leaves a thin, slippery layer of silicone reducing friction on plow blades. You’ll move snow more easily and efficiently while using less fuel.
This product is easy to use. Simply spray, brush, swab or roll onto plow blades and other exposed metal and painted surfaces. Let dry for 30 minutes for best results. You can also apply after equipment use for optimal rust protection.
One gallon will last you for many years . I put it in a spray bottle
