I've been trying to figure out what is causing the engine to run at high speed. I've replaced the governor links and checked the throttle. What I did notice though was when I removed the link from the governor shaft, the governor shaft moved to high speed. Should it not move the opposite way? Is there some spring or something inside the engine that operates it that may need adjusting?
Any help would do as I'm just a rookie.
-Tecumseh LH358SA 159630A HMSK110
-Horizontal shaft
-10.5 HP
Hopefully that is enough info.
-Horizontal shaft
-10.5 HP
