Ariens 1332 , Tecumseh Snow King 13hp can not regulate rpm's , seems to be that governor is not working please HELP!!!! Thank you Chris:eek:
If the governorhas not been touched and there hasn't been any other engine problems the the rpms going up and down is probably in your carburetor.
See if there is a small screw with a spring on it in the center of the nut that holds the fuel bowl on.
If there is turn it a very slight bit out. See if that helps. By slight I mean about 1/8 of a turn
