I was given an old H70 in good shape. I am going through the machine and found it does not like going from Rev or Neutral to 1st-3rd. Once it is in 1st, I can shift fine up to 3rd and back to 1st, but it doesn't like going back into Rev or Neutral. I have to push it pretty hard to get in to switch gears. Is this a common issue? What should I be inspecting?
im assuming its using a rubber friction wheel. did u lube all the moving parts/cables/pivot points
I haven't touched anything, except changing the carb since the previous owner snapped off the choke lever.
To clarify this old post. The unit was an old 910965 supposedly from 1971. I noticed that the two bolts holding the front and rear housings together were stripped out and 1 bolt was missing. I retapped the threads and secured the unit together. It shifts much much better now.
