Headlight Help - Bulb Access?
1 reading
3.4K views 7 replies 7 participants last post by  SayItAintSnow
I'm helping a friend that has a MTD two stage from around 2000ish that has a headlight. It is model S31A6C0F022. If you look at all the diagrams on it, it shows a built in square headlight (likely an option). Well he bought his new from a local hardware store and his has a round headlight.
Similar to this: https://www.finditparts.com/product...Mmuu-K139213-L159&gclid=EAIaIQobChMIwM7c66-X2AIViS-BCh0A0gb6EAQYByABEgIpEfD_BwE
It has stopped working. I only had a minute to look at it, but it appears there is no way to open it and get to the bulb to replace it. If I confirm it has power to the leads, I think the only option is to replace the entire unit. Can anyone confirm that? The link I provided above also states "sealed rubber housing".
#2 ·
Without seeing the machine. I had one that the light appeared square, but was an actual round bulb behind the mounting. And I was able to order a bulb at O'Riellys. I think it had a plate on the back side with some screws that you removed to get at the bulb. It is a PAR36 bulb, Wagner 4414.
#6 ·
Yes It is most likely a sealed beam that is available at most hardware stores. Canadian Tire carries them here in Canada. Make sure your getting a good ground. Many times the ground is the problem with these lights. You can pop the sealed unit out of the rubber housing and check the unit with a continuity meter to see if its burned out. No flow through the terminals it is burned.
#7 ·
Thank you all for your comments. I took a look at it again and it is just like the link I listed in my original post. There appears to be no access to the bulb and the entire thing appears to be replaceable for $10. The hardware store must have added it. When it was running I disconnected the main wire to the light and plugged in a volt meter and grounded the other end. I got no reading. I should have gotten 12V right? My guess is the light is fine and the coil that powers the light is bad or the wire is.
#8 ·
EVH,
What setting did you have the meter set to? AC or DC?
It's likely that an MTD from that era used a halogen sealed beam unit, that works off the stator current.
That would be AC however.
If you measured it as DC, you'll get a zero reading. On the AC setting, if you still don't get a reading, make sure and try a couple of different ground points, just to be sure, before you consider it dead.
