There is a gap between the headlight lens & the black plastic panel that it fits into on my Craftsman blower. I need to seal it some how otherwise rain, snow, dirt, etc. will get in the housing. Any suggestions how this could be done? I'm considering using RTV silicone.
Would pick up some 100% silicone. That will do it. I would just caulk the top and sides, leaving the bottom alone in case any condensations gets inside
+1. This would be about the ONLY time I would recommend going to a big box store. Pick up a tube o Silicone (should be about $3.00, assuming you have a caulk gun) and have at it. If your really good you should be able to trowel it out and have it look professional.
Seems all good now...
Thanks cdestuck & liftoff1967.
Well prior to reading this, I had at it. The lens is held in by 2 aligning tabs at the top & 2 locking taps at the bottom. I needed to remove the lens in order to put a bead of the RTV silicone along the edge of it. Even though I was being careful, I did manage to snap the top 2 tabs off. But it went back together just fine without any gap! I had already put the silicone on so I just left it there figuring it'll make an even better seal that way. I'm thinking that there was a problem with one of the top taps with caused the gap.
