Been lurking a while so thought I'd finally join. Grew up on a farm so I'm a tinker by heart. This years first snow fall proved my little 1 stage wasn't going to cut it so looked at new and didn't find what I wanted so I started looking for used blowers. Bad enough I had to keep digging my place out but I also had to dig out the Daughter/Granddaughters place. I liked the old gear drive transmission Murray/Craftsman units so I first picked up 3 to rebuild into 2 working units. Found a pair of 4 hp 20" units and a 5 hp 22" blower. Mixed and matched parts (using the best parts on the final blowers), ended up with a 4 hp electric start blower and a 5 hp electric start blower - one for home and one at the daughters. Both start the first or 2d pull of the rope with the electric starter as backup.
Here's what I started with (working 4 hp in back, then parts machine then the 5 hp unit - before I changed out the wheels) after the rebuilds and parts swapping:
Then I stumbled onto a 7 hp 26" with drive issues for a bottom-feeder price. Well the front transmission mounts were broke off, so I found a parts chassis and the transmission mounts were broke on that one too. Not one to give up (and being too cheap to buy a new transmission), I designed and made my own transmission mounting system to reuse the original Tecumseh transmission and it worked. I stole the low speed needle out of the crap 4 hp motor and rebuilt the carb on the 7 HP and had a running snowblower.
Here's the 7 HP compared to the previous 5 hp one on the left - I'd already changed out the wheels to pneumatics on the 5 hp:
Here's what the broken transmission mounts looked like before I made my repair kit (I'd already cut off the damaged are in preparation for the repair parts):
Changed out a few things like putting pneumatic tires on the 4 & 5 HP units, swapped out the plastic drive axel bushings on the 7 HP with some metal ones from the 4 hp unit etc. I'd like to find something comparable to those metal bushings but with a 1" id to do the auger on the 7 HP, but haven't found any yet.
Next thing I plan to do is split the controls on the 7 HP one. Right now you can't engage the auger without also engaging the transmission which I don't like. I'm going to remake that so it's like the 5 hp - one control for the auger and a separate one for the drive.
I don't feel too bad, around $400 invested, 3 working blowers and a bunch of spare parts, including 2 extra auger gear housing and transmissions.
Pretty much sums up regarding my snow equipment, except I kept my 1 stage and snow shovel for when those apply.
Paul
glad to have you. nice work on the machines. for a while plenty of friends and family would joke or laugh when I pulled something out of the garbage or spent $10 on some rusty hulk in a backyard. but they all come a knocking when their new tin toy falls apart and the need to borrow my tank-like iron that is still purring. even though the tanks are 45 years old
Glad you decided to jump in HCBPH! Nice looking job on your snowblowers. Few things more satisfying than making something work again.
Thanks
Thanks for the welcome and I appreciate the comments. I'm another one that enjoys seeing something given a second life. Having grown up on a farm, if it broke you fixed it and that philosophy is something I still believe in. Whether it's wood working equipment, metal working equipment, cars, etc; many of my things are old or even older than I am in some cases. I like seeing something that someone else viewed as junk doing it's job again. I honestly think that these machines will outlive me, given proper care and maintenance.
I do have one complaint though. I was still in the process of repairing and rebuilding the 7 HP blower when we had the last big snow this year, so I haven't had a chance to try it out other than moving some snow around in my back yard. It's snowing again today, but just a dusting from what I've seen so far so it's going to have to wait a while longer to see how well it works.
Paul
