1 - 14 of 14 Posts
Would anyone have a repair manual that they could post/or email me a couple pictures of how to disassemble to get at the clutch
Thanks David
Are you referring to the auger clutch?
Yes I have developed a noise in that area sounds like bearing going it goes away when auger engaged but is their when it is not engaged
Dave
There is a bearing, behind the impeller, in the auger housing. Could that be it? (#13)
Thanks db9938 the noise i have is when the blower is not engaged, when the blower is engaged the noise goes away
David
I would think that the noise would be much further back then. After the 6, 8 mm bolts that hold the back of the impeller housing against the aluminum housing, there only one bolt holding the clutch in place.
Not really much too see. Case, gears, and clutch. Pretty simplistic, makes me wonder why they didn't upscale this into a larger unit.....?
1 - 14 of 14 Posts
