I have a honda hs 624 - manual is a 1992 havent looked at serial number- got this gem running but prev owner wore down wear bars in past housing- would need to weld some sides back on-- My question is where to get new cutter bar and skids- Any help please
Boats.net is one of the best sources for Honda parts.
Thanks for the info great site for parts-I am wondering how much to put into this old of a machine- any thoughts from honda owners out there?
well depends. any pictures?
depends on extent of wear and tear? good compression? good operations or are things all bent out of shape.
post some pics. I have a HS624 that appears almost new. I think it is 20 years old. also have a 34 year old HS50 that runs well.
Honda's will last as long as you take care of them. parts are expensive but I feel worth it. or you can get an old donor machine for used parts.
I have a 1992 Honda HS624 for parts-owner wore down past wear bars- and carb is junk- It does run tho and has many good parts- no tires or rims - I am in mid michigan-local pick up only - 150 for whole unit
