1 - 20 of 32 Posts
· Registered
Gents,
My search for a good used Honda on tracks has brought me to some models that look good via the pictures, however I'm really trying to dig into their details before I can put hands on them to check out the actual mechanics that I've learned need to be checked prior to purchase (thanks to all you guys via the many many threads on SBF for that knowledge :)).
So how do I decode the serial numbers into a manufactured year? I've searched the forums and I can't for the life of me find a thread that talks about this. I've also seen posts that say they changed the fuel caps from black to chrome on a particular year, or the exhaust pipe color etc., I'd like to learn what years all that type of stuff transpired. Some of the sellers I've contacted simply don't know the year of the blower because they bought it second hand or they've lost track of time etc.
For instance one I'm currently looking at is a HS624TA (serial: szaj-2100722). I take it most models have the serial # on the rear of the blower toward the bottom (see pic) correct? Is there guidance out there to decode this to the year it was produced?
I know these things will run a long time with proper MX but really wanting a model not over 5 years old. Greatly appreciate your help in advance!
· Registered
I bought mine (928 tcd) it is 8 years old , didn't even give it a second thought. To get the numbers decoded I called Honda Canada and they gave me all the information that I needed when I registered the machine. Honda USA should do the same for you, Just give them the numbers without registering the machine.
· Registered
I want to call Honda Canada as well to get same information.. but I sincerely can't find a phone number in honda.ca
Do you know where you found the number to call?
Thanks
· Registered
Honda snowblowers don't have model years, but use K-codes to note running changes. A version may be in production for years or just months, some never get any changes, others are changed 7, 8, 9 times over the product life.
This particular unit was wholesaled by Honda to a dealer in September 1997. The first retail customer bought it in October 1997 (Rogers, MN). This model was built in Japan, perhaps in late 1995, but more likely sometime in 1996. There are no pending updates or recalls active for this model/serial number.
· Registered
Discussion Starter · #8 ·
Thanks Robert!
· Registered
Thanks guys for this info. I just purchased a used HS1132 today for $900. Seems like an awesome deal. I wanted to know the age so I followed the advice here and called Honda. Got it registered, found its model year (2006), and checked open recalls (which it has one).
Thanks for the help!
-AHODA
Contact info I used for Honda USA:
American Honda Power Equipment Division
4900 Marconi Dr.
Alpharetta, GA 30005-8847
Customer Relations
Tel: 770-497-6400
· Registered
-AHODA
4900 Marconi Dr.
Customer Relations
Tel: 770-497-6400
You got a smoking deal!
· Registered
what year is my honda snowblower serial no. szas1136642. email me at [email protected]
· Registered
Gents,
· Premium Member
There's the decoding I provided for the model numbers in the sticky section, but there's really no decoding available for the serial numbers other than knowing which set of parts diagrams to use. As I and others have already stated, simply contact Honda USA or Canada for that information.
· Registered
That is a later HS928 (pre-K1). Probably about 2010-2011. Call Honda to get an accurate delivery date.
I now this is an old thread, but I am join the Honda Japan Party late LOL, I am looking at a HS-928, with SN# SZAS 1173323, what generation 928 do you think this is? there is paint missing on the chute, very little wear indicati
172364
172365
on on the auger housing, have these photos:
172366
· Registered
Ahh I just read this, will do, but a comment on paint condition would be welcome!
· Premium Member
That's a small joystick transitional unit, so I'm guessing it's from the tweens. Let us know what you find out!
If it's in fact from the tweens, it looks good for its age. There're some auger teeth that're bent, but otherwise isn't showing much wear.
Reactions: 140278
1 - 20 of 32 Posts
