1 - 20 of 456 Posts
Dear Honda HSS snow blower owners,
Thank you for your ongoing patience concerning the chute clogging issue on HSS724A, HSS928A, and HSS1332A snow blowers. We apologize for the frustration, and again, we appreciate your patience as we have worked to solve this issue. Producing an improved chute design for wet and heavy snow conditions has taken longer than any of us wanted.
We would like to give you a preview of the new chute. A larger U-shape opening has been incorporated into the chute. Our extensive testing shows this solves the abnormal clogging issue.
As soon as the new chutes are available, American Honda will provide servicing dealers with the information needed to order and install the new chutes. We anticipate release in early October. This repair will not be a recall – recalls are only for safety-related issues. However, please be assured, the repair will be available under warranty if you have experienced this issue.
As we stated previously, only a very small number of snow blowers actually experienced this issue – mostly in the New England area. The original snow blower chute seems to clog more easily than expected under certain wet and heavy snow conditions. The new chute design does not improve performance outside of these conditions. For this reason, if you have not previously had clogging issues, you do not need to replace your chute.
We would like to note that all snow blowers will clog under certain severe conditions – that’s normal for all snow blower manufacturers. This new chute will address abnormal clogging issues. It may still clog under severe conditions, but that should occur much less frequently.
If your snow blower has experienced this issue, you should contact your local dealer in early October. Installation of the new chute will need to be performed by your dealer and will be covered by warranty.
If you have questions or concerns regarding your snow blower, or need help finding a local dealer near you, please contact the Honda Customer Relations Office at 770-497-6400 or visit powerequipment.honda.com.
Again, we apologize for the frustration this may have caused. Thank you for your patience.
Sincerely,
The Honda quality team
Thank You Robert.
My dealer told me with the new chutes, the work light will be covered with snow when the chute is pointed in that direction.
A quick additional update on [email protected] Unfortunately he is not back on the forums yet. We hope he is able to return soon.
Please continue to direct queries to our Customer Relations team for the fastest response! Thank you for your understanding.
Looks like an easy do it yourself kinda deal if would be an out of pocket repair. Good photo. And there's your dinner....
Thank you for the update, it's good to get some official info.
To avoid assumptions, if a machine is out of warranty, the owner would have to pay for the new chute, even if they are experiencing clogging?
I would like to ask Honda the following simple question(s).
Will the update be a no charge if the snow blowers 3-year warranty has lapsed?
If NO, would it be at no cost if we were to make it known to our dealer that we want the upgrade now before our initial 3-year warranty laps?
Would we need to provide an official Honda bulletin number while making the request for service with our dealer?
Also, if there be a time limit (beyond the 3- year warranty) for having the upgrade completed, what would it be?
I ask these questions because as of today's official response from Honda, all units in the field ARE still under warranty (but many won't be for long). This makes there following statement potentially ambiguous:
"However, please be assured, the repair will be available under warranty if you have experienced this issue"
Any time limit that would force us to send our snow blower to the dealer this winter (service can often take weeks) would not be acceptable.
The attached photos are helpful. While I haven't experienced issues with my machine in Calgary, it is nice to know the fix is so simple and a DIY for those of us that wish to do it anyways. I know Honda took some unpleasant comments from members here, so I appreciate you keeping your cool. Just knowing the fix is simple is reassuring in case we do get the problematic wet stuff others get on the east coast.
I certainly plan to keep my HSS724 ACTD for a long time and have a deposit on a second single stage 720 as soon as they arrive in Calgary soon.
Thanks Honda.
Cut the bloody thing off, ski wax the chute and be done with it. what is so hard about that??? anything in the path of the snow stream will create friction and melt water.
1. Cover the light with a warmed up wide piece of roll up kiddee sled to make a shroud and glue it on the housing with gorilla glue or super glue.
2. Use the rest of the kiddee sled heating it up on the chute to form it and then glue it to the chute if you do not want to use stainless steel elevator bolts.
The previous model did not have any of this and it worked well from what I have gathered.
If Honda acts in "good faith" they should extend the warranty for this repair as it took a couple years to address the problem.
good luck.
So, after extensive research, Honda came up with a fix that someone on this forum has done at least 6 months ago. I hope the Honda R&D team didn't have to spend a great deal of overtime copying the proposed fix.
That may have been me. I think I was the first to "hack" the chute - at least to document it here. Here is my thread:
https://www.snowblowerforum.com/forum/honda-snowblowers/100538-hss928-clogging-%5Bsolved-%5D.html
Not sure I will bother with the time and effort to have it changed to the updated chute. It will be interesting to see cost of the updated chute. Manufacturers usually have lower prices on parts that are involved in a recall or TSB. That way, the manufacturer has to pay less profit to the dealer on the warranty claim. For the record, I paid $80 CAD back in 2016 for a chute.
Will the little remaining material on the baffle will solve the headlight loading-up-with-snow problem? Time will tell once the updated chutes make it to the field.
Sincerely,
Will Honda also cover pickup and delivery service to have the fix installed?
Sent from my SM-T800 using Tapatalk
I ordered this chute on ebay and expect it to arrive tomorrow. Wonder if I'm just as well off the install this instead of waiting in line to have dealer install under warranty.
Thank you, Robert! Honda is standing behind it's products! I had the hydraulic cavitation warranty work done on the 928 this summer and will get the chute replaced in the fall. Bravo, Honda!
I contacted Honda with the questions asked here:
tabora: Thank you very much for posting the update regarding chute clogging on the snowblowerforum.com site. Many forum participants were early adopters of the HSS models and have the following concerns:
Will the update be at no charge if the snow blowers 3-year warranty has lapsed?
If NO, would it be at no cost if we were to make it known to our dealer that we want the upgrade now before our initial 3-year warranty lapses?
Also, if there will be a time limit (beyond the 3-year warranty) for having the upgrade completed, what would it be?
Honda: All chute replacements will be performed on a case by case basis for units in or out of warranty to make sure that customers that have a clogging issue are taken care of under the warranty.
We know that customers in the New England area have this happen more often but in other parts of the U.S. never has clogging issues.
Bulletin numbers will not be needed for the customer to present to a dealer since every dealer in the affected areas already know about the clogging issues.
We have a data base of customers that have reported the clogging issues so if the warranty has expired it would still be covered by the warranty.
We hope this helps, thanks for your email.
PE Customer Relations
"We know that customers in the New England area have this happen more often but in other parts of the U.S. never has clogging issues."
HSS928 Clogging in Bend Oregon to the point of sending snowblower back to dealer for 90% refund.
Thank you for reaching out to them, and sharing the reply.
This concerns me slightly. The implication is that if you reported having clogging issues before your warranty ran out, then you're on a list, and they will do the bulletin for free.
But what if you had the clogging problem, but didn't report it to Honda? There are plenty of things about products that irritate people, but they don't necessarily report them officially to their vendor, or the manufacturer. I'd imagine there must be people with clogging, who didn't write to Honda.
I guess one approach would be to contact Honda now and report it, if you've had clogging problems, to be safe.
Cut the half ring off the bottom and paint it before you mount it on the snow mule.
If you look closely you will see the half ring weldment is tilting inward into the snow stream as it exits the impeller housing NOT GOOD.
Go ahead and paint it use some turtle wax on the chute in several coats, then hang a snow brush on the snow mule to clear the light off. It does not matter whether I use the JD junk or the snow pups I use the space heater preheat the engines and to melt it all off and dry it out as they are exposed to road salt, thanks New York State for wasting my tax dollars.
1 - 20 of 456 Posts
