How much should I offer for a Ariens ST826, may be a 824, with a blown Tecumseh engine with a big hole in the side of the block. Range, low side, high side. It has a light, garage kept, good tires, no rust. I probably will put a Predator 212cc engine on it.
Check gearbox first, those aluminum units are usually worn to bits. $50 is what i pay for those units. Maybe $100 if its in really good shape. Predator fits nicely, some need the 3/4 to 1 shaft adapter, then longer studs for engine mounting. Have done many without a single problem.
