1 - 20 of 31 Posts
This hopefully takes some of the mystery out of testing the interlock / safety circuit on Toro snowblowers starting around the 1981 model year.
You shouldn't hook-up a voltmeter to the interlock modules...it could burn-out the internal circuit.
Tools you'll need:
  • Spark tester
  • 2 jumper clips
  • continuity meter (for the interlock circuit only...not the interlock module itself)
If the module itself fails, good luck finding one; they're NLA but do show up occasionally on eBay.
If the module passes however the interlock circuit (consisting of harness, handlebar switches, auger limit switch, gear-select limit switch) has bad continuity. Start by cleaning all of the connections and testing individual components. Use dielectric grease on the contacts to preserve them for years to come!
Excellent explanation of how the safety switches work in relation to the infamous module. "I" still want to dissect a failed unit to see what is inside and possibly duplicate the mystery electronics. Thanks Buddy.
Reactions: classiccat
Discussion Starter · #3 ·
No problem Grunt! I know this mystery has been plaguing you more than anyone!
A dremel is probably the best tool for the bulk delayering and a chemical approach for touching down.
This circuit is tricky b/c you don't want it interfering with the normal ignition; If you don't have that sharp change in the primary current that this circuit is stealing from, the secondary charge will be weak.
My gut is telling me that since it's a current-driven circuit, it's feeding into the base of a BJT...and one of the 2 n/p junctions of that device gets roasted killing that isolation.
Darn it Grunt, now I'm curious! :icon_cussing_black:
My interest is in the "Survival of the species" ideology. If people junk their machines because they won't start, won't operate with the few safety protections there are, an inexpensive way to reproduce the module might keep these old monsters alive for another 30-40 years.
I just thought of an old saying, "Curiosity Killed the Cat". Maybe you shouldn't get involved in this any further. I'd like to keep you around. :kiss:
Grunt & 'Cat:
Gentlemen...you've piqued my curiosity about this, mostly because, even though I have heard of some snowblowers having safety interlock circuitry, I've never acutally worked on one that did. :question:
Not sure I understand what the manufacturer's philosophy was here, but looking at the schematic, is it nothing more than they were trying to insure that you couldn't start the machine if the auger lever or drive lever were set to the engage position? Or is there more to it? :icon_scratch:
At any rate, it would seem to me that a solid state relay of the type that we used to see frequently in old computer equipment, could probably be used as a substitute. There used to be tons of these around from the surplus electronics vendors inventories, of varying voltages and currents.
Typically, these modules would be completely sealed in an epoxy cube or rectangular shaped pack, which would pretty much assure that they were impervious to moisture issues. The only caveat in trying to use one of these for a snowblower, that I would offer, is the question of reliable operation through a range of typically cold temperatures, but I would guess they would be o.k. It'd certainly be cheap enough to try. :wink2:
Many of these modules have quite a range of "control" or "trigger" voltages. For example, you can easily find ones that have trigger voltage of 5-40 vdc, so you don't have to rely on a perfectly stable voltage. You could even run one of these using AC as a trigger, if you first run the trigger voltage through a full-wave bridge rectifier.
Though the plentiful and varied supply of these seems to be drying up from the surplus electronic dealers, the market has shifted to Ebay, where there are still plenty of them to choose from. I would guess that even if you had to add a bridge rectifier, you could get out of the whole deal for less than 15 bucks. :yahoo:
Discussion Starter · #7 · (Edited)
Grunt & 'Cat:
I’m afraid that this circuit is not going to be as simple as folks hope (a simple relay is a convenient analogy for explaining operation however they don’t work for starting and killing).
- a NC relay for killing won’t start
- a NO relay for starting won’t kill
The voltage on the primary wire is going to be quite high (several hundred volts).
My guess based on when this technology was implemented (early-80’s) is that it’s borrowing ideas from CDI. It will have standard diodes, zeniers, caps and resistors and then the magic will be possibly from one or more of the the following: SCRs, BJTs, Triacs or even an old school FET for switching.
Probably similar to the patent 3,726,265 by William A. Howard for magneto ignitions.
We’ll see, I have a failed unit soaking in solvent to try and loosen-up the potting.
^^^ that's the ground plane connection peaking out already
I've never have come across one.
Can they be disconnected and bypassed?
I've bypass my JD1032.
Classiccat:
My impression as to how this worked was based solely on the simple schematic that appears at the end of that video. My assumption was that the circuit allows one of two conditions:
1) allow voltage to feed the ignition module
2) cut off voltage to the ignition module
So, is there more to this than simply preventing the engine from starting when either the auger or drive is engaged?
So the stator on this engine is producing a voltage of several hundred volts? Obviously it's not the voltage going to the spark plug as that would be several thousand, not several hundred volts. Why is it so high?
Pondering this in real time here.......
Wait......Is this setup from before the days of solid state ignition modules?
Lol....and I thought I was confused before.....:devil:
Sorry for all the silly questions, and I hope you don't mind, but I am curious about its purpose and how this is supposed to work when everything is fully operational. :wink2:.
It looks to me that your second image, along with reading the patent, provides enough detail to almost copy it.
Right, but the patent does overcome those problems.
From the blue box at the upper right in the Google web page you linked to, you can download or view the full .pdf (it's easier to read than the Google web page).
No magic (your second image explains it) and Toro may have licensed the technology from the patent holder. Or maybe Toro broke the patent and has or had its own patent.
I was going to suggest that you might want to build upon that patent in an attempt to break it but, curiously enough, it looks like the patent expired today.
I'm in no way an expert and these are just my random thoughts.
Discussion Starter · #11 · (Edited)
Hey JLaw! You can disconnect it (along with the safety features) as long as you have a way of grounding the kill wire (most of our machines do this with the throttle).
Classiccat:
The schematic at the end of the video is to demonstrate the relationship of the microswitches, on/off switch, handlebar switches and interlock module.
Think of the interlock module delivering current to the safety circuit…and it can only deliver current if there is continuity through the safety switch circuit.
Starting:
- Auger and traction are off and neutral respectively
- Note: It's possible to start the machine with auger or traction engaged if the handlebar switches are held down. So you shouldn't hold the handlebar switches down when starting.
Operating:
- either of the handlebar switches must be depressed when auger &/or traction are engaged.
-- wheel clutch models have 2 handlebar switches so you can use either hand to work the clutch
Unintentional Kill:
- engaged tractor &/or auger without a handlebar switch depressed.
The stator is not producing power but rather the charge coil within the electronic ignition module.
When the flywheel magnet passes the charge coil, it induces a current that charges-up a large capacitor.
Then as the flywheel magnet passes a trigger coil, a “switch” (silicon controlled rectifier) allows this capacitor to discharge into a transformer that steps-up from a ~ 200V (Tecumseh coils) to 20kV for spark.
I believe that this interlock module is stealing some of that power from the Charge Coil / Capacitor to power-up the safety circuit.
EDIT/NOTE: Briggs Magnetron / electronic ignition is different (not CDI) however still the general concept of drawing current generated on the primary winding.
I'm fairly certain that toro only implemented these with electronic ignition.
@Grunt, we're getting close! Soaking in simple acetone and carefully scraping with a razor knife is clearing away the potting material.
A little capacitor is peaking out there:
GAfternoon,
"The stator is not producing power but rather the charge coil within the electronic ignition module.
I believe that this interlock module is stealing some of that power from the Charge Coil / Capacitor to power-up the safety circuit."
This topic is discussed on a couple other Forums.... That is the consensus, that the Interlock Module Steals a small amount of current from the ignition coil when running. If the safeties are not in the proper position, that exciter current will be grounded thru the safeties and kill the engine spark. It seems SO Simple...... Yet at last check, it has not been duplicated cheaply OR successfully. Although those Interlock Modules aren't used very much anymore. It did work well....usually until some well meaning frustrated operator tried to 'By-Pass' it !!!
The last one I was able to purchase, was NOS, and priced at $55, and that was 3-4 years ago. Haven't needed one since, luckily!!!
I do have 1 good used one left. I try to grab them from machines that are junked.
Patiently waiting for The C/C to find The Answer to this one!!!!
GLuck, Jay
Discussion Starter · #13 ·
GAfternoon,
GLuck, Jay
You and me both Jay!
Well, we'll at least have some clarity on the module for Tecumseh CDI igntions; the module (41-8601) I'm reverse engineering is from my '89 824.
I'll still need a dead module from a briggs (41-8610) and there is 1 year (1981) that Toro used interlock 41-8600 on the points Tecumseh engine.
So net on the Toro interlock modules:
826: 38150 (Briggs powered):
  • 1980: No interlock module; grounds the magneto directly
  • 1981: 41-8610 (magnetron electronic ignition)
  • 1987: 41-8610 (magnetron electronic ignition)
824: 38080 (Tecumseh powered):
  • 1980: No interlock module; ground the magneto directly
  • 1981: 41-8600 (Magneto points ignition); you can still buy this module on partstree.
  • 1987: 41-8601 (Electronic CDI ignition)
Discussion Starter · #14 · (Edited)
Ok guys, I think I got this finally nailed down. Patience, acetone and a hobby razor knife were the only tools required.
I mirrored the circuit board backside to ID components.
Single ceramic capacitor...
^^^ the only thing throwing me is the "P" suffix on the top-line; that's not a normal tolerance value.
3 resistors:
SCR is indeed the magic sauce...and finding a replacement is going to be a little tricky...especially since some of the label pulled off. @Coby7, i believe you have a background in electronics... you probably have some good cross reference tables?
^^^ i was lucky in that the "sticker" was still stuck to the potting material and mostly intact! So i mirrored it and lined-it up to get an educated guess on the missing alpha-numerics:
overlaid:
Equivalent Circuits:
I'll need to double check my handywork (my wife is pulling me away from my desk :) ) but this circuit operation makes sense...and is quite slick in its simplicity.
Finding that SCR that works with these voltages and temperature ranges could be challenging. That cap is rated to 500V...Tecumseh charge coil will be in the 200V range i believe.
Now I need one from a Briggs-powered Toro!!!
Ceramic capacitors are usually high in voltage tolerances. SCRs are also very tolerant as far as specs. So if yours as failed you should be able to find a suitable replacement. Is it shorted out?
Thank you CC, that is an amazing amount of detective work. Your attention to detail is unmatched and your wife's tolerance to your investigation is greatly appreciated. Thank you Mrs. CC.
:rock:
'Cat & JayZ'
Gentlemen, thanks for taking the time with the explanations of the theory of operation of this device. Yes I can see this is a fair amount more involved than I initially thought.....:wink2:
The circuit itself looks simple enough though, and I have to say 'Cat, isolating that circuit board was borderline "archeological" level retrieval...You are clearly a much more patient guy than I am!
I wonder if you sent the same photos you have of that SCR to customer service at outfits like Mouser Electronics or Digi-Key if they would be able to help you out with a suggestion. Even if that semiconductor is no longer manufactured, there's gotta' be something out there that will be a good substitute. :icon_scratch:
Great job!!! :icon-clapping-smile
BTW...what model Toro was that? I want to make sure I have nothing to do with any of those in the future .....:devil:
Discussion Starter · #18 ·
Yeah these class 2 ceramic caps are all over the place with temperature... trade-off of the high permittivity dielectrics.
It's only job in life is to hold a potential on that SCR "gate" between pulses (when the interlock circuit is open).
I haven't desoldered the components yet for final "postmortem"...my $$ is on the SCR however it's plausible that the CAP took a dump.
There are 2 other markings on the other side... green and white lines.
Discussion Starter · #19 ·
:rock:
You're very welcome Grunt (from the both Mrs. CC and myself!) She's extremely tolerant of my antics!
It's always fun getting back to my roots; I was actually an industrial electrician (after my grunt days back in the 90's). I'm now an E.E. but the devices my team and I fabricate require a scanning electron microscope (SEM) to see. :nerd:
Next step is to source these components and make some for my Toro brothers!
Discussion Starter · #20 ·
'Cat & JayZ'
yeah we'll find that component! I actually started looking at the online mouser catalog this morning...good idea ripping them and digikey an email to see if they can come up with an equivalent. :thumbsup:
As i said earlier, '81 through I'd say '89 or '90 use these modules...IMHO, their best years! I've also read that there are some early Ariens models that also have an interlock module...supposedly less prone to failure.
1 - 20 of 31 Posts
