Hey guys. Posted last season about my HSS1332 running lean. Still having same issue even after taking it to a Honda dealer for service.
So when I figure it up, and push the choke back in, it surges really bad and backfires constantly unless I pull the choke part way out.
This means it's running lean right? Cuz when I pull the choke part way out I'm choking some of the intake air and reducing the air going into the carb?
Anyways, took it to honda last fall while it was still under warranty. Told them about the surging.
They couldn't replicate the issue, although when I started it to load it on the trailer, it was surging like crazy. Dunno what's wrong with Honda...
Anyways they told me the carb was likely filthy and the issue, seeing as it was 3 years old at the time. They said that's not covered and I'd have to pay for that service if it was the issue, no big deal I'd pay them to clean carb if required.
Turns out the carb was apparently spotless. Probably because I only run Shell 91 with 0 ethanol in it.
I paid them to install a bigger jet, 110? Whatever you guys said to get I forget now.
Also told them about a service bulletin for the auger lever not staying locked in place and wanted that fixed with the new revised parts. They didn't do that either, just fiddled with the cables and made things worse. Now the drive lever stays engaged sometimes, and both levers feel loose and cheap now and shake a lot.
Also my joystick was acting up, wouldn't move the chute to the left. Showed them the service bulletin for that too. Guess what, couldn't replicate it. Didn't replace the joystick. Had to buy a new one myself 2 weeks after I picked it up.
Sooooo Honda has proven to be more than useless with my machine. Gonna have to take on the repairs myself.
What's possibly causing the surging? The machine runs good and strong under full load, just runs like ass at idle.
Also, when I got it back from them, the piston that holds the blower at different angles with the thumb lever seems to be leaking and doesn't hold it any more. If I lift it up the bucket all the way it sinks down pretty quick on its own.
So a few things I need to tackle.
Just bothers me that this was all under warranty and they literally did nothing.
Thanks guys.
Sent from my Pixel 5 using Tapatalk
Thanks guys.
