Chain "stretch" is caused by lack of lubrication and then the chain’s pitch grows in length as it wears. The growth comes from the bushings wearing with the chain pins. Over time, the inner diameter of these bushings increases and the pins groove out. Measure the length of 10 links and then divide by 10 to get the average pitch. If it's 0.5% greater than the original pitch (or more), it's time for a new chain, and perhaps new sprockets.It appears the chain is stretched.
Tabora , I am impressed ,your explanation of "chain stretch is text book spot on " . I can't tell you how many mechanics I have explained this to ,only to get a deer in the headlight look .Chain "stretch" is caused by lack of lubrication and then the chain’s pitch grows in length as it wears. The growth comes from the bushings wearing with the chain pins. Over time, the inner diameter of these bushings increases and the pins groove out. Measure the length of 10 links and then divide by 10 to get the average pitch. If it's 0.5% greater than the original pitch (or more), it's time for a new chain, and perhaps new sprockets.
Have you checked to see that the pin in the drive wheel is intact on the left side? Does the chain actually skip on the sprocket when you turn the track?
Yeah!!!!! I am going to need some visual aids to explain that one. BROTHER!!!!!!Chain "stretch" is caused by lack of lubrication and then the chain’s pitch grows in length as it wears. The growth comes from the bushings wearing with the chain pins. Over time, the inner diameter of these bushings increases and the pins groove out. Measure the length of 10 links and then divide by 10 to get the average pitch. If it's 0.5% greater than the original pitch (or more), it's time for a new chain, and perhaps new sprockets.
Think of it as an axle wearing out a bronze bushing. As the bushing becomes elongated you get more play in the axle. With a chain, since they're all linked together, as the bushings elongate the chain grows in length increasing the pitch. The pitch is the distance from one link to the next.Yeah!!!!! I am going to need some visual aids to explain that one. BROTHER!!!!!!
Yup, looks like the skip is inside the transmission...Next step is a new transmission
So disappointing. Is there anything I could try to get it working? If I need to buy a new one anyways might as well try something.Yup, looks like the skip is inside the transmission...
Here is how you check your transmission fluid:Is it possible to add fluid at all? I feel like it might have been slowly leaking out while I was using it but couldnt be sure if it was oil or just rusty water dripping off.
I always learn something from your posts Tabora.Chain "stretch" is caused by lack of lubrication and then the chain’s pitch grows in length as it wears. The growth comes from the bushings wearing with the chain pins. Over time, the inner diameter of these bushings increases and the pins groove out. Measure the length of 10 links and then divide by 10 to get the average pitch. If it's 0.5% greater than the original pitch (or more), it's time for a new chain, and perhaps new sprockets.
Thanks for the help. I don't believe mine needs the external tank. Mine is a HSS1332ACTD SAFA-1015166.Here is how you check your transmission fluid:
Is yours in the serial number range that need to have the external oil tank retrofitted? If so, I would do that, too.
Parts are in the upper left of the diagram.
Someone told me that they used a black zip tie with a sharp 90 degree bend at the 2.5" mark. I have not had to do it myself.Is it best to use a popsicle stick or something to check the level? I'll give it a try thanks.
There are not a lot of replacement parts available other than the seals, etc. The whole transaxle is $700+...Is anyone able to find any info/parts diagrams?
