I don't think there is anything wrong with the steering triggers and the gears engaging/disengaging. You do need to adjust the side where the gears still make a little contact when the trigger is pulled.
The left side on mine free wheels but, makes a little contact when the trigger is engaged. I also removed both L/R cables and tested but, it didn't help when giving it a running test. I did however, bend the PS cable up slightly which helped with the clearance of not making contact during free wheeling. Other than that cable being a little stretched, there isn't any other adjustment that can be made other than adding a thrust washer between the c-clip and retaining ring per service manual
pg 26 Here. I checked the gap in which it will just accept a thrust washer as a shim. I disassembled both L/R sides of the power steering assemblies, cleaned and relubricated them and the axle and tested.... Unfortunately, no luck. All the teeth on the gears looked great.
So when the machine is running just sitting there still, those brackets don't move back and forth constantly?
No movement at all.
Only after you engage the drive lever to move forward? Correct.
I'm just not seeing what is wrong. First time seeing this and have never heard of this problem.
That makes the two of us.... It's really strange to say the least.
You said you replaced two springs when you replaced the drive friction rubber ring?
Yes. I thought since I'm changing out the friction wheel rubber, I might as well change out the two springs. Simply due to being 18 years old.
Did this problem exist before that repair?
Yes. The problem started the fist time this year when I was snowblowing after I was running it for about 20 minutes. I have never disassembled anything prior this over the years. All I have done is clean, lubricate, oil change and empty the fuel. Engine starts 95% of the time on the first pull.
Maybe the new springs are wrong?
Exactly the same o.e.m. Upon installation, I matched them up just in case.
What did you take apart to replace the drive friction rubber ring? I followed the two following video's which is on an identical snowblower as mine but, Craftsman. Everything is very straight forward. In addition, "I always" take photo's and video and right down the steps I perform. In addition, YouTube! & Forums! 😊
DIY - Drive Ring Repair On Craftsman Snowblower
HOW TO REPLACE THE BELTS ON YOUR SNOWBLOWER - Craftsman, Husqvarna, Poulan
Maybe something went back together wrong?
Everything Easy Peasy.... Straight forward.
I took more video over the past couple days in which I'll get out hopefully later today if not tomorrow. I was able to take some running jacked up video on a couple 4x4's and underneath as I was giving it a test run. 😱 Also you'll see a difference on each side of the drive axle in regards to length. I ordered two axle bearings, two clutch slide springs and a couple thrust washers pg 33 Here due here by Tuesday. At the end of the day during a test run..... the problem remains, unfortunately. 🤔🤨 Thanks again for your help and thoughts along with hanging in there with me. I appreciate it!
