1 - 3 of 3 Posts
For close to a $1000 bucks and 3 years into this machine, I will never buy another Husqvarna anything again. 3rd issue. First LEDs not working, plastic fuel cap undoing itself while running the machine and now a fuel leak. Insane.
Fueled up my machine today for snow season, turn the fuel valve ON (valve itself is metal) and I start seeing fuel pouring out. Took off the shield and it seems to be coming from the valve and or the hole its seats into on the tank. Hard to tell.
Are these units prone to this issue? I was thinking of filling the tank with water and turning the valve to see if I can pinpoint the issue rather then gasoline. Tank is currently off the blower.
this isn't a Husqvarna issue, The engine is a LCT made engine and Ariens also has the same brand. Actually good engines but a few shortcomings and that switch seems to be one of them. There are videos on youtube to repair them or you can just get the replacement. Just gave a new life to a engine from a ST227P on a different blower and has the same shutoff valve.
So I think my leak was coming from the base of the shut off valve that connects to the fuel tank. Looks like some I assume gasket glue seals it. I tightened the valve and it seems to have stopped the leak.
Immediately I pull the unit out to do some snow blowing and it doesn't go into gear. I take a look under the shifter level and it's all plastic and the connection that connects to the plastic rod completely broke off I mean I just can't believe that what a piece of **** this thing really is a plastic connector at such a critical point that takes so much force.
In the second photo you can see the flimsy plastic that has torn off.
1 - 3 of 3 Posts
