I have a Toro 824 OE model 37798, I believe a 2021 model. I recently posted about some of the issues I am having break the auger bolts Toro claims do not break. But I have broken about 2 dozen bolts now in maybe 10 hours of use as my snow in SW colorado at 6700 is very warm and thick. Yesterday I broke over a dozen in 6 hours of clearing over a ft high of snow. Local dealer sells me oregon 1/4" shear pins, $10 for 10 with the locknuts, so certainly affordable. But what a pain to be constantly breaking them and then having to stop, get on my old knees and hammer out the broken pin and sometimes go less than a minute in thick snow and break the bolt I just installed.
I do have the speed adjusted as low as I can go and I also am using the left side clutch drive lever to "stop and go" every ft or so through the thick packed snow, but I still break the bolts eventually even going at a snails pace. Truth is they just do not make the Toro 824 able to go slow enough, I am always in first gear, only time I use a higher gear is when I have a broken shear pin and I am going back to where I have my tools and new shear pins to install. Maybe there is a mod to make these go slower, I would do that as well.
I am considering drilling out the auger and auger shaft holes from 1/4" to 5/16" and then use the larger 5/16" shear pins that Ariens and many other blowers use. I figure some of the repair guys here will tell me either never to do that as it will transfer the impact to the pricey gearbox or damage the auger shaft/augers, or maybe go ahead and try it???? I am not hitting rocks or other obstructions, just heavy thick snow that has settled in place as the ground here will not freeze and we have been getting really heavy snow this year from the big california storms. It is really too much for this Toro 824 OE is my feel on the heavy snow I am experiencing, but it is what I have.
So what do you think, is it worth a try or not, or will I destroy the gear box??? No warranty issue as I bought the machine last year 2nd hand.
