My 2015 machine had the clicking from new, when powered and when moving around manually. I took the Auto-Turn apart and there was very little grease in there and it was hard. Cleaned out the unit and filled with grease and the clicking stopped altogether. There was no visible wear, and that is now my spare since the grease seals cannot be replaced by factory units. I bought a new Auto-Turn and used it this last season and no clicking at all, so probably has much more grease than earlier models. No difference in functionality.
are they meant to be greased? (dissembled and greased)?
there is no visible grease in the video, so wondering (?) you stated the one you dissembled had grease in it, am I understanding that correctly?
Wondering if I should be dissembling mine and lubing it somehow. I can't imagine this would be routine maintenance...
If the gear were in ones hand, there'd be an axle hole in the middle, so a pen oiler would make putting lube between those teeth easy? (haven't had mine off the axle so just guessing this is the case?) OTOH, if too slippery, the teeth would not engage/lock and drive the machine forward (?)
Feel like I'm missing something w/ this part. Thanks.
