1 - 3 of 3 Posts
I have a John deer 1332 DDE No reverse! I have replaced the friction Disc, no help. I have made all the adjustments to the cables, clutch drive ect. NO Help. I have noticed that the drive disc flywheel sides back and forth just a little bit. Is it possibly a bearing going bad? Any help would be great Thank you
A video is the best with you moving the lever back and forth. Stand the blower on the auger housing, remove the bottom cover, and move the handle back and forth. While you are doing this, then hold the drive lever down using a clamp and turn the drive wheel liking at the rubber friction disk and friction plate.
1 - 3 of 3 Posts
