I have a 1970 JD 726. Tecumseh HK70 engine electric start. Belonged to my grandfather. 100% garage kept. We've used it on and off through the years. When it works it is unstoppable. Mostly sits in the garage and has been un-used for 10+ years or so. With so much snow I have taken on the project to get it going. If I spray in some carb cleaner it will turn over for a few seconds. Yes the carb is dirty. I removed the bowl and found it black so I am trying to remove the whole carb and either clean or replace. The two nuts that hold the carb against the engine spin along with the studs. So I can sit there and wrench and wrench and spin and spin. I do not believe there is a head on studs on the backside of the assembly for me to attach a screwdriver to nor is there very much room. I'm wondering what I am doing wrong or how I will remove that carburetor.
I believe my problem is the same as this forum post.
Should I try to remove that intermediate manifold piece with the two phillips head screws? Is that the only way?
