I have a John Deere 185 with a snow blower on it. When I toggle the switch to turn it on, the motor dies. I've disconnected the drive belt to the blower (it's all free) and still have the same problem. I suspect a grounding or bad connection issue. Any ideas? :confused:
I would guess you are on the right track with suspecting a bad ground or connection, possible even a faulty switch?
Discussion Starter · #3 ·
How embarrassing! Found my problem. I had put a block of cement on the back of the tractor behind the seat to give it more traction (already have 4 weights). This caused the seat to move up, and of course opening up the safety switch that's under the seat. Luckily I didn't get as far as taking the tractor to John Deere. All's well that ends well.
Life is always good when the solution is simple. Glad you figured it out.
How did you figure that out? That's not something I would have even been close to thinking about checking.
Dan
