Awhile back I was having problems with fuel delivery and spark on my sno-tek lct 208cc engine.
To adjust the valve, I used the rope in the cylinder trick, then turned the engine by hand, just enough to keep the valve in place.
I made all the adjustments, turned it again by hand to remove the rope, put it all back together, and it fired right up.
I had been using the electric starter, but now every time I try with the pull start, the kickback is terrible and has even broken the handle while being pulled out of my hand.
What did I screw up and what should I check to fix it?
