Hey guys, just used my snowblower after getting 30-35 cm of snow and I noticed at the end of using it while cleaning it off that there was an oil “ puddle” in the snow .. back right corner ...
I guess it would help to know what type of snow blower along with a photo or two.
One from a not so far distance and one close up.
Too few details to help.
I'd wipe it down and look to find where it's coming from. Sometimes you have to degrease it to find the problem.
On a new-to-me blower I though it was a slow leak. Turns out it was a massive leak! Ran it for a bit, figured it was coming from behind the flywheel, so tore it apart to find it had kicked out the seal. Put back in only to blow it out again... turns out the crankcase ventilation was not correct. Airbox did not have a hole drilled in it properly. No cost repair but still cost an hour or two of my time, as I pulled it apart at least twice.
First thing is check the oil level in the machine and see if its low right now. Is it possible that you overfilled it last time you did an oil change?
Check the drain plug make sure its there and tight enough. Don't over tighten it or you could crack the base of the block.
Check that the dipstick, if you have one, in in and snugged down, and that the dipstick tube where it goes into the block is in place and no oil is leaking from there.
Depending on your engine model, there MAY be a couple of leveling plugs , usually yellow with a couple of raised knobs on the top to get a screwdriver between them to loosen, near the bottom of the block. These are used to check the oil level instead of a dipstick sometimes. Some people have reported one or both of them coming loose and oil leaking out.
In general, when posting questions here, its a good idea to give make and model, year, and photos if possible showing the engine, and any other areas that are giving you specific problems. If you can find the engine number as well, that can be a help as many machines of same or similar model may come with different engines.
