Thanks and yes, that is the same as the Ariens RapidTrak, but not my question. Those two adjustment eyebolts and nuts have a very large range of movement to apply enormous tension or very little tension to the rubber tracks. So how much tension to apply?From initial inspection of the Toro, you loosen the back idler bolts and at the very back of the track assembly, there's a jacking bolt on either side to increase or reduce track tension. Fairly simple
Does your Toro manual describe a method of setting track tension?
