1 - 3 of 3 Posts
I'm working on a neglected Ariens 924038 with a 7HP Tecumseh. I presume it's an HM70 but the top is too rusty to clearly identify.
I removed the nasty carb for a good cleaning and noticed one of mounting studs was loose. I was able to apply just enough force on the attached throttle bracket to hold it while I removed the nut. After cleaning the carb I am unable to tighten the nuts on the mounting studs- now both carb mounting studs are turning even if I try to leverage the throttle bracket to force the studs from turning.
Is there an easy trick to solve this issue? I considered using a dremel to grind a slot in the stud head for a screwdriver. Otherwise, I'll need to dig into more disassembly to get behind the mounting studs to determine a better approach.
Thanks in advance.
Take the small manifold that carries the bolts (they aren't actually studs - they go no farther than the small manifold at the right in your picture) off the head (the philips bead bolts for that are visible - to the right and just below the nut with the arrow) and ensure that the appropriate lock washers are behind the bolt heads.
Take the small manifold that carries the bolts (they aren't actually studs - the go no farther than the small manifold at the right in your picture) off the head (the philips bead bolts for that are visible - to the right and just below the nut with the arrow) and ensure that the appropriate lock washers are behind the bolt heads.
Great idea-- I should have thought of that~ thanks!
1 - 3 of 3 Posts
