Hey guys, new to the forum but long-time lurker. Just pulled the trigger on a HS828TA with significant impeller housing (auger housing is beautiful) damage I think occurred from using the blower on a gravel driveway. Otherwise, blower is in fantastic shape.
I'll be breaking down the snowblower to take apart the impeller housing, changing out the oil, cleaning the carb, etc. I know there is a lot of wisdom out there on what little "mods" or "upgrades" you can do to help make the machines function to their max capability. That having been said, I can't find a post that generally outlines all of the different suggestions in one place - so hopefully we could get started here?
For example:
Must: adjust cutting bar . . . . set skids to ⅛ for clean driveway (paint stick) or more for uneven surfaces. When replacing nuts, apply anti-seize.
May: Fluid Film inside auger housing and chute
If taking off the auger, auger housing, impeller etc: just install new bearings, this is a wear point so just upgrade . . .(again, just a hypothetical)
Would be great to have a "checklist" of things to work through for people new to the hondas that are buying 20+ year old machines with unknown histories - either all at once, or "if you're doing this make sure you do that"
Thanks!
For example:
Thanks!
