not really smartThe worst it could do is break off or wear out. I set my poly material up to rub and wear in. Even solid metal could be used with a little clearance. 🤔
Have you done this? I was wondering about it but that it could cause jams with rocks, sticks and such whereas the rubber has more leeway for stuff like that.The worst it could do is break off or wear out. I set my poly material up to rub and wear in. Even solid metal could be used with a little clearance. 🤔
much better than mudflap. My mudflap mods only lasted 3 seasons. This stuff lasts and lasts.This what I've used for 2 that I did. Got it at tractor suppy.Thick enough but not a pain to work with. I use 1/4 rivets but you have to have the big rivet gun, helps to have the extended nosepiece.
Just checked the website...Now it's $49.99.... Yikes!This what I've used for 2 that I did. Got it at tractor suppy.Thick enough but not a pain to work with. I use 1/4 rivets but you have to have the big rivet gun, helps to have the extended nosepiece.
You could better buy a kit of your buying that. I do have some that we replaced off a baler this fall if you need some.Just checked the website...Now it's $49.99.... Yikes!
Most automotive tires these days are steel belted. As such, they're terrible for any kind of DIY project. But, many motorcycle tires are corded belts.Tires with corded belts (not steel) will work.
The mud flap I bought is for 18 wheelers and the strips have held up fine for 6 years. It is constructed like older tires were (corded). It's pretty rigid, but with a little flex.much better than mudflap. My mudflap mods only lasted 3 seasons. This stuff lasts and lasts.
I have a roll...Just rechecking the price.You could better buy a kit of your buying that. I do have some that we replaced off a baler this fall if you need some.
